Subject: Bombproof, But Not Fireproof!
10/02/2004 12:18 AM
Kent’s 1965 CJ-5 Tuxedo Park Mark IV (limited edition, we believe that there were about 2000 made in 1964 and 1965) was a thing of beauty and home-grown engineering. The Jeep sported ‘77 Dana 30 and AMC 20 axles (OX locker up front Detroit locker in rear) with Warn HD axle shafts in the front and Moser one-piece axle conversions in rear. Tom Wood built long-spline CV-type drive shafts to send power from the T150 gear box/Dana 20 T-Case combo to the axles. 4.88 gears turned the 38.5” TSL Super Swamper SX’s which were mounted on American Racing 15X10” rims. To stop the rig, Kent installed Stainless Steel Disc Brakes.
The rig road up high, cleared the big meats and flexed well with a custom shackle reversal, 4-inch Skyjacker (Wrangler) springs and a custom spring-over lift. 4 ProComp 3000 shocks kept the rig from po-go’ing down the road.
To give the over-size CJ5 some get-up-and-go, Kent installed a Chevy 350, 4-bolt main mill, which was filled with a hot Crane Cam/lifter combo, a Holley intake and Holley Truck Avenger Carburetor. To keep everything cool, Kent installed an all aluminum Griffin radiator with twin electric fans, a power steering cooler and an oil cooler.
A few other mods included a Warn 8000 lb winch, custom frame work, custom bumpers and more.
Rather unfortunately, Kent’s rig caught fire while trying to climb a steep ledge. Kent believes that the carb overloaded with fuel from sitting at such a steep angle and gasoline ran down the back of the engine and all over the exhaust. When Kent went to restart his rig there was a backfire which ignited the fuel. After exhausting more than 2 fire extinguishers, the rig go too hot to continue extinguishing efforts.
When talking to Kent during the ordeal, all he could muster was “No carburetor can replace fuel injection”.
Fortunately, Kent’s wife was quite understanding of the whole ordeal and Kent is now in the process of building a 1985 CJ5. We’re pretty sure that he’ll be installing fuel injection this time!
BEFORE PICS:
[img]http://www.4x4review.com/oops-pics/JeepFire/before/DSC00400.JPG[/img]
[img]http://www.4x4review.com/oops-pics/JeepFire/before/DSC00401.JPG[/img]
[img]http://www.4x4review.com/oops-pics/JeepFire/before/DSC00402.JPG[/img]
[img]http://www.4x4review.com/oops-pics/JeepFire/before/DSC00404.JPG[/img]
[img]http://www.4x4review.com/oops-pics/JeepFire/before/DSC00405.JPG[/img]
[img]http://www.4x4review.com/oops-pics/JeepFire/before/DSC00406.JPG[/img]
DURING THE FIRE:
[img]http://www.4x4review.com/oops-pics/JeepFire/fire/p1010001.jpg[/img]
[img]http://www.4x4review.com/oops-pics/JeepFire/fire/p1010002.jpg[/img]
[img]http://www.4x4review.com/oops-pics/JeepFire/fire/p1010003.jpg[/img]
[img]http://www.4x4review.com/oops-pics/JeepFire/fire/p1010004.jpg[/img]
[img]http://www.4x4review.com/oops-pics/JeepFire/fire/p1010005.jpg[/img]
[img]http://www.4x4review.com/oops-pics/JeepFire/fire/p1010007.jpg[/img]
[img]http://www.4x4review.com/oops-pics/JeepFire/fire/p1010008.jpg[/img]
[img]http://www.4x4review.com/oops-pics/JeepFire/fire/p1010009.jpg[/img]
[img]http://www.4x4review.com/oops-pics/JeepFire/fire/p1010011.jpg[/img]
AFTER THE FIRE:
[img]http://www.4x4review.com/oops-pics/JeepFire/after/burnt jeep 12.jpg[/img]
[img]http://www.4x4review.com/oops-pics/JeepFire/after/burnt jeep 13.jpg[/img]
[img]http://www.4x4review.com/oops-pics/JeepFire/after/burnt jeep 16.jpg[/img]
[img]http://www.4x4review.com/oops-pics/JeepFire/after/burnt jeep 17.jpg[/img]
[img]http://www.4x4review.com/oops-pics/JeepFire/after/burnt jeep 23.jpg[/img]
[img]http://www.4x4review.com/oops-pics/JeepFire/after/burnt jeep01.jpg[/img]
Wish Kent luck on his new rig by dropping a post here!
sublmnl1990User is Offline
10/07/2004 3:48 PM
Man that sure was a nice Jeep, good thing no one got hurt send me some pics of your new jeep in progress. Thanks Nick sublmnl@cox.net
PatsplaceUser is Offline
11/08/2004 9:11 AM
Too bad about the fire, lucky no one got hurt and that the woods didn't catch. Good luck with the new ride. Pat
11/08/2004 6:59 PM
A couple of the trees got pretty crispy, but they never caught. Thank goodness! Rick
rsg1963User is Offline
01/15/2005 1:23 AM
I actually FELT that loss to some degree. I am truly sorry that happened, and it makes me wonder what I can do to prevent the same from happening on my rig.
01/16/2005 3:54 PM
Couple of things that come to mind;
1) Double, err... triple check ALL of your fuel lines and fuel line connections. 2) If you're using rubber fuel hose, check them frequently! Look for cracks, abrasions and chaffing. Fix and replace as needed. (I change my rubber fuel lines every other year regardless. It's cheap insurance) 3) Always carry at least TWO fire extinguishers on board. They can be bought for about $20 each at Home Depot or a similar place. 4) Check your wiring... this is an arduous task to say the least, but electrical fires are more common than fuel fires. 5) Check hot-spots, such as headers and catalytic converters. They put out a lot of heat and should be clear of anything flammable, and properly shielded. 6) Know how to use a fire extinguisher... there are so many people that just don't know how to use them.
I'm sure there's more, but that's all that is coming to mind right now.
Good question rsg1963.
n/aUser is Offline
09/22/2005 9:26 PM
man!! sorry about your rig.There is aplace in all are heart's that go out to you.glad to see your ok.happy day's with the new rig.
UNRULY 1User is Offline
09/10/2007 4:43 PM
Ouch!
BEASTMODE88User is Offline
01/02/2008 2:21 PM
Wow that seems pretty unreal.
brandyUser is Offline
03/04/2008 6:17 PM
sorry about that it looked reel nice . man if mine cought fire i think i would have gone with because theres nothing like a bond between man and truck. with deep sorrow see ya!!!
4wheelsonlineUser is Offline
05/26/2008 3:39 AM
Ouch.. Bombproof but fireproof not?
Does it really happen?
Discounted Trucks, Jeeps, SUVs [url="http://body-lifts-4you.com/"]body lifts[/url] online. Great Price of [url="http://hummerlift-kits-4you.com/"]Hummer Lift Kits[/url]
Forums > General Discussions > Oops Pics > Bombproof, But Not Fireproof!
